I have a "classic" soldering gun that barely gets hot. Inside, there isn't much to go wrong, it seems. A 2-speed trigger switch, a big coil of fine wire that goes through a coiled sheet steel cylinder, and a light bulb.
How can I troubleshoot this? The light bulb lights up, and I have cleaned the contacts of the tip. Voltage across the tip is only about .3VAC, but I have no idea if that is good or bad.
