Crowning sheaves
  • Crowning sheaves
    I have volentered to make two flat sheaves of 4in. diameter. One to be 6in. wide and one 10in. wide. They are to run a 6in. wide sanding belt. I believe a crown is necessary to keep the belt on track. I looked in the mach. handbook but could find nothing. If anyone remembers a good " rule of thumb " in this regard I will appreciate seeing it.
    Thanks in advance.
    Jim
    Jim
    I don't think you need a crown on one that size if running two wheels. On a 2x72 square wheel (3wheel) grinder the idler pulley is ever so slightly crowned and it's the tracking adjustment. I can tell you that too much crown makes it overly sensitive when adjusting. If I really wanted to find out I'd make the wheel flat and then build it up a little with electrical tape in the middle and see how it acted.
    On my 4x48 neither of the belts are crowned but one end has the tracking adjustment.
    Sounds like a macho grinder you're working on
      The book recomends 1/16" on diameter per foot of face. That works out to 0.148 degrees from centerline to one side, or 0.296 degrees included angle
        Sheaves
        Bringing in the Sheaves:
        http://au.youtube.com/watch?v=rPQsQI...eature=related
          YOD, I just finished my 2X72 grinder and made it to plan guidelines. It called for 2* crown from centerline both ways and that SOB is way too sensitive for tracking. I am going to remove some crown using Brian's posted formula and try again. I was wondering why it was so hard to track that thing.
          Thank you guys.
          Patrick
            Only the driven sheave needs a crown. If you crown both they tend to "argue", making centering unstable. Better to have less crown than too much - that causes instability too.
            The axes need to be well aligned since the crown only provides fine guidance.
            John
            Edit: http://www.visusa.com/belt_tracking01.htm
              John
              According to the link, my tracking wheel is totally wrong cause it's an apex crown. Damnit. Take it apart and stick it back in the lathe.
                Originally posted by Your Old Dog
                On a 2x72 square wheel (3wheel) grinder the idler pulley is ever so slightly crowned ...
                Doesn't that square wheel make for a sort of bumpy grinder?
                Lynn (Huntsville, AL)
                  Never heard of "knocking the corners off" ??
                  You might not like what I say,but that doesn't mean I'm wrong.
                    Wheel crown
                    I was involved for several years in design of large bandsaws and maintenance equipment.
                    Most important is that the wheels not be low in the center of the tire.
                    Second is that you need to be careful that the structure not deflect when belt tension is appied. The belt, band or in this case sanding belt will tend to center up on the tight spot and if the frame deflects, will run off the wheels.
                    In setting this up, use the crown on the driving wheel and keep the rest of the wheels VERY slightly crowned.
                      I neglected to say what this is going to be used for. I am doing this for the local First Robotics competition group. High school kids. In my opinion it is a fine opertunity for the boys and girls.
                      The belt is part of the "play-ball " handling mechanism.
                      The 1/16th on dia. is what I have so far. The second sheave is being glued as I type this.
                      Some tape wound on might help to determine if more or less crown is needed.
                      Thanks all
                      Jim
                      Jim
                        I've heard that the R.O.T. is 1/8" per foot. Have used 1 degree on the compound and the pulleys have worked out well.
                          Shop wisdom
                          Thanks jdunmyer.
                          That's the "rule of thumb" that I've used - and was told to use over 55 years ago!! I could not find or confirm it in "Google" or else-where - still can't.
                          It seems to be a traditional "word of mouth" hand-me-down "shop/job wisdom" thing that just "works" - which it certainly seems to do.
                          I think it was a curve/crown with a rise of 1/8" per foot and a chord equal to the pulley/sheave width. I have done them with tapers instead of curves/arcs and they seemed to work OK but my "gut feeling" is to use the curve.
                            This seems like a good thing for Human Numerical Control. A graphing calculator or spreadsheet = easy, can use parabolic or what ever.
                              To state the obvious, that gives you a linear taper/crown. I was told that linear crowning (with a flat spot in the center) was recommended over a radius, but according to the article GadgetBuilder posted, the big-boys use a radius crown on most pulleys, and save the linear crown for wide, thin pulley like a conveyor pulley.
                              Lane once posted a cool picture of a radius jig that was a long bar on a pivot.
