Parlmgren Rotary Table "Just needs a good cleaning"
  • Parlmgren Rotary Table "Just needs a good cleaning"
    That's what the ad on flea-bay said. I kept trying to find a decent rotab without buying a newer one made offshore . After bidding on more than a dozen this one popped up.
    Then after spending about four hours in the shop on it, I show the end result.
    Total cost $204US including shipping. IMO thats better than a new chiwanese rotab at any price.
    MIKE
    Bricolage anyone?....one of lifes fun games.
    MIKE
    I have one of these I bought used back in the 80s... it works fine for what it is, but a horz./vert. table w/ tailstock and w/o the x/y axis would be more useful to me...
    Nice job w/ the red handwheels...
    - Bart
    Bart Smaalders
    http://smaalders.net/barts
      Looks nice. I've got a similar version in my shop, though not as gussied up.
      Makes a good bolt circle tool (and the like) for a drill press, but pretty useless for milling. I haven't done it, but it could also be used to mount a vice or the like in order to set the angle (or adjust a feature on axis) and then run coordinate from there.
      Russ
      Master Floor Sweeper
        What is the problem that makes them useless for milling? I've never seen one let alone used one. I presume you mean the x-y table part?
          "not good for milling" WTF that thing looks disassembleable.
          If not you might still modify it for use on the table...
            I have one too (hush Lane ), and the table doesn't have a positive clamp with the base, so the table tends to lift up during milling operations.
            However, it makes a fabulous drilling table, especially with the x-y adjustment. I have the two-piece vise jaws that Palmgren sold seperately, and it's really useful on a big drill press.
            Nice build quality too, by the way.
              Well, IMO, it is not suited to milling for several reasons. The cross slide castings are relatively light and the screw mechanism also relatively light. Then stack a (again, relatively light) rotary casting on top, and add a round table top that looks (disarmingly) beefy. But you've got back-lash and flex in every direction. Considering all the talk of eliminating the rotary base from Kurt vises to reduce flex, and it's pretty obvious that these Palmgrens (and similar) have issues in that department.
              Not only that, the cross slide is on the "wrong" side to be useful on a mill. In that location it serves the same function as the mill table, so it's adding all sorts of problems for no benefit. Cross on the top is a WHOLE different ball game, but they are completely unrelated devices. And the worm drive for the table is absolutely tiny compared to a comparable milling rotary table. The "locks" (using that word lightly) for the table are also not nearly sufficient, and there are no locks on the cross slide (that I recall anyway). Basically, I would put use of this on a milling table at about the same functional level as using a drill press as a mill. Ok, maybe a bit higher as long as you use nothing bigger than 1/4" in aluminum, or perhaps ok for doing micros in a PCB or something.
              Just my opinion, and I'm sure someone is going to say that they have used one for milling for years with good results, but I believe that a good look over one of these will dispel most thoughts of using it as a milling rotab. I've got the 12" model, and it doesn't even cross my mind to mount it on a mill. It is, however, great for mounting on a drill press, locate the table co-axial with the spindle, and crank out to a bolt circle radius (or otherwise locate it), then sit-n-spin...
              Russ
                Maybe the steel is a bit too hard, but then a nice carbide corn-cob rougher should mill it quite nicely
                ....ducks and runs
                  Ha! I almost made a similar statement, but decided against it...
                  Russ
                    Thanks, Lazlo and BD - that's the kind of thing you can't see in a picture.
                      I'll echo the "suffers from anemia (lack of iron)" comment; I've laid out plenty of bolt circles w/ mine, but the few slots I've done were tricky to keep right. The curved slot on the aluminum bronze slip eccentric drive on the steam engine in our 19' boat took a long time to do, and it is tiny. The ratio is pretty fast as well, which doesn't make it any easier.
                      - Bart
                      Bart Smaalders
                        LOL. Odball, you beat me. I have the exact same one , but mine cost 31 dollars.
                        I havent used it yet, though.
                          Nice job you did on the restoration welll done. Alistair
                            Nice job, looking good.
                            Would you use linear motion under the rotary table on a mill?
                            Nick
                              I got one of those thrown in with my mill, although I'm not sure if it's a "palmgren" or a knockoff of the same. One of the t-slots is off-center (one arm shorter than other), so not that well made.
                              I used it the other day as a rounding table to round off a small brass part on the Bridgeport. It worked "OK" although the handle to rotate the table is a bit stiff. Seems to rotate 9 degrees per rotation of the handle.
