LOL! lolcats on the forum! Internet memes go mainstream... Hey, it rhymes.
Question About Last Thursday's Plane Splash
Originally posted by Teenage_MachinistLOL! lolcats on the forum! Internet memes go mainstream... Hey, it rhymes.
*dives for bomb-shelter*This product has been determined by the state of California to cause permanent irreversible death. This statement may or may not be recognized as valid by all states.
Plastic Operators Dot Com
Originally posted by David E CoferI see your ***** cat and raise you a 85lb psychotic pitt bulldog.. Surely not this 100lb wimp snoring on my couch thou. He hides behind me when loud noises happen.
OKAY.. wanna talk real fast in poor engineering?? how about a ducted fan jet engine, the ducts have flappers that dump anything ingested be it flat-top carrier crewman or bird that travels down the duct??
Seriously, we're still de-bugging the anti-grav lifters, so how else would you do it? The new F-35 VTOL operates the same way: there's a ducted fan behind the cockpit."Twenty years from now you will be more disappointed by the things that you didn't do than by the ones you did."
Originally posted by aboard_epsilonW......ell geese seriously effect the flow into the engine, don't they ?
would there be a need for them to be so fine and massive as that one in the test pad
they could have holes inch by inch ...with sharp edges like a fries cutting machine.
then geese would be chopped up into inch chunks that the engine could survive .
all the best.markj
Then we create another problem,what happens when this screen breaks?
Basically there is no simple solution to what seems like a simple problem.I just need one more tool,just one!
Intake screens are not an impossibility but probably not worth the expense:
The reason for that is because all their runways are crumbling.Free software for calculating bolt circles and similar: Click Here
It makes sense to me to guard the intakes as the Russkies do..... opens up more options........
I thought about the various approaches....... Screens are obvious non-starters.... The screen necessary even withstand impact of birds at 2 or 3 hundred knots is just way too heavy to be considered seriously.
Some helicopters have sand-removing intakes, which spin or otherwise change air direction to drop out heavy items.
The stealth fighters have intakes that are not directly forward-facing, and the concept has the potential to exclude heavy or massive items (relative to air).
But all of these solutions have energy and weight costs. YOU are cheaper in the long run. A few people are killed, but in general the results of NO protection are likely a net positive, per operational analysis.
And, as we see, not every maximum-case bird strike results in fatalities. Apparently both engines lost essentially all thrust at about 3200 feet, according to the paper today.
It doesn't get a lot worse than that.... except maybe losing thrust at Orange County, where steep climb rules are in force for noise abatement... just as you enter the climb. That sounds considerably worse.CNC machines only go through the motions.
Originally posted by lazloMost Russian fighters (MiG-29, Su-27,...) have intake covers that are deployed during taxi and takeoff. Air is pulled in from vents above the engine intake.
Much higher resolution version here:
I suppose you could design a plane with doors to do just that,but building a wing with an 8-11' diameter hole in it would be difficult
Best and probably cheapest solution-
Originally posted by wierdscienceA turbojet can breathe through the top of the wing and produce thrust where a turbofan cannot since the engine is used instead to spin a fan which produces thrust.That air flow problem again.
But the fan is run on a separate shaft, the familiar compressor and turbine are used as a gas generator for the fan turbine, with some actual jet thrust. originally the fan was just an augmentation to the jet thrust. But if you look at new aircraft like the 767, or Airbus planes, the fan is the main feature, the large fan duct forms the main apparent bulk of the engine. I don't know the exact thrust ratio fan vs jet.Last edited by J Tiers; 01-19-2009, 11:30 PM.CNC machines only go through the motions.
Originally posted by CirclipFirstly, the outcome and expertise of the handling of the incident is to be applauded and congratulated and shows the skill and dedication of the whole of the aircrew involved.
BUT, the pilot does in fact run training exercises in flying disaster management, has had an initial training regime far in excess of a "Normal" airline pilot, and lets face it, he is paid to be able to safely drive an unatural mode of public transport. It never ceased to amaze me when landing in bad weather conditions (Rain and Blow) how passengers clap as soon as the wheels hit the deck? This is the guys JOB, we don't do it through lack of skill or capability, how would he fare tuning a carb or setting a manual machine to make a ballturner.
I'm not trying to detract from the bravery, but he did exactly what many with far less training and flying hours did in driving "Horsa's" and "Hotsper's"
Regards Ian.
I think the fact that he went down in a calm river, as opposed to open water with large waves, played a major role in the successful outcome. If there had been 10 foot waves, the results could have been really bad.
Originally posted by J TiersYou'd be hard-pressed to find a pure turbojet these days..... virtually everything flying is a turbofan engine...... They look just the same, other than the larger intake, and they virtually ARE the same...... You could, at the risk of terribly offending the ME types, say that a turbofan is a turbojet with extreme amounts of compressor air bleed.........
Looked at some Rolls product last summer,nice big titainium composite fan,blades have hollow crossection.Don't remember the number but the fan even though it was pushing 9' in diameter was very light.
Here's a Trent 900 eating chicken-
And a destructive test,9 million pounds,down the tubes-
Originally posted by wierdscienceThe picture showed a fighter jet,the last bastion of a pure turbojet.
They are useful up into the supersonic speed range.CNC machines only go through the motions.
