VDF Lathe Question
  • VDF Lathe Question
    I have this VDFlathe it is a V 1 Boeringer, quite old but in good
    nick.However I do not understand the purpose of the gear/s with the
    numbers on it.
    The lathe can cut Metric, Imperial and Modular threads it has a 8tpi
    leadscrew.Here is a link to a photo of the gear/s
    http://farm4.static.flickr.com/3478/...82a891302a.jpg
    Can anyone help?
    Thanks
    Dick Ellis
    That's pretty odd. There's another gear on the same shaft as the numbered gear, but the teeth seem to have a different pitch.
    Can you zoom in on the gear in question in a new picture please?
      I think it is some sort of dividing head. The planetary gears give you some ratio.
      A better pic would help. I blew it up and it is very intriguing. Can you also post some pictures of the total mechanism? I think there will be something else that is "odd" that will support the "dividing head" theory and help in counting revs.Lathes.co.up say that vfd is a marketing name. Is there a model number or other info?
      Or it might be something else. My success ration on these guesssing games is 8%.
        I found a little info, it was on PM.
        http://www.practicalmachinist.com/vb...d.php?t=130702
        They have the specs and an old catalogue.
