Crankshaft Pins?
  • Crankshaft Pins?
    I am curious what material are crankshaft pins made from? Nitrided 4340 ?? I may have to make some. Lucky my friend is a Guru of Centerless Grinding. Thanx Mike
    I assume we are talking 2-cycle cranks...snowmobile maybee??? I don't know exactly, but they are weldable, I don't think 4340 would weld without heat treatment after without cracking . The ones I was welding were 800 thundercat cranks that the guy had put some 1200 Pierce cylinders on with a 3-stage nitrous set-up.....would throw the crank out of whack without tigging the pins in the cheeks...He said it ran a best of [email protected] before loosing the motor at a 1000'...not to shabby for coasting the last 300'....It just had a short fuse that's all..also the pins are usuallya little tapered and knurled / splined depending on who mad the motor(yamaha had some with X-hatch some straight ,and some not at all) Good luck , Shawn
      God knows what the US spec is but we used to make them out of EN39B.
        Depnding on what you need you can buy crank pins from various manufactures:
        Just need the od and the length
        (you can order longer and cut )
        see wiseco as an example:
        http://www.wiseco.com/Catalogs/Power...ngsWashers.pdf
        please visit my webpage:
        http://motorworks88.webs.com/
          Some discussion on crankin material here:
          http://www.practicalmachinist.com/vb...ghlight=franco
          franco
