Water jet Cutter?
  • Water jet Cutter?
    Hey Guys how do i Make my own small one? thanx I really would like one for some Tile work i want to do, thanx Mike
    First requirement, jet of water, 0.4mm diameter running at 33,000psi.
    You might not like what I say,but that doesn't mean I'm wrong.
      The new ones are up to 80,000psi if I remember right.
      They do make a small waterjet kit that you retrofit to a mill, I've seen it in the trade mags and maybe on the PM site. I don't have any links for you though, maybe tiffipedia can scrounge some links up.
        You could make your own small waterjet cutter.
        You could also make your own small space shuttle, or build a working V12 500hp aluminum block engine.
        But it aint cheap.
        There is a reason a new waterjet machine starts at around a hundred grand, for the smallest ones, and quickly heads up to about a quarter of a million.
        And it aint that the waterjet companies are making a machine for 30 grand and then making $220,000 profit.
        First, a pump- a pump that will do 80,000 psi is not available for free off your old dishwasher. A pump running at these pressures must be extremely precise, made of very high quality, expensive materials, good bearings, machining tolerances to 4 or 5 digits, and so on. Its not uncommon for pumps like these to cost $10,000 to $20,000 to rebuild, and need a rebuild every couple of years.
        Then, there is the head- they use industrial diamonds or rubies, mostly, for the nozzles, and every part of the system is subject to extreme wear- its not just water, they mix an abrasive in for most applications.
        Yes, the actual x-y table mechanism is similar to one for a cnc plasma- which means cheap kits cost about $5000 to $10,000, while industrial quality rigs, capable of throwing 1" plate on and bumping with forklifts, and running 24-7, are about $20,000 to $50,000 just for table and motion controls.
        I know a few guys who run commercial waterjet- and if that machine aint working all day, every day, they are losing money. Utilities, consumables, regular rebuilds- at $100 an hour, two shifts a day, they barely make a dime.
        If you have tons of free motors, computers, racks and pinons, motor controllers, and steel, you could probably fudge together the table part pretty cheaply- but even surplus, I cant see the waterjet pump and head costing less than ten or twenty grand, and thats for worn out, obsolete stuff.
        I knew a guy once who spent years trying to build his own laser- he never got one running.
        Some stuff just takes a lot more industrial infrastructure than I have in my shop.
        Knuth does sell the cheapest one I have ever seen- $70,000.
        I imagine its chinese, but you can go to their website and see it-
        http://www.knuth.de/v1/frameset_usa.htm
