How can I reverse this motor?
  • How can I reverse this motor?
    Hi.
    I have this single-phase motor but having done a little research I'm still not sure if it can be reversed. The two windings are connected in parallel with the supply, and the only connections are on those two posts. Can it be reversed or not?
    Monarch 10EE 1942
    Reverse the way the starting winding (on the right in your diagram) is connected to the switch and the capacitor.
    Or, reverse the way the run winding is connected (middle in your diagram) is connected.
    Do whichever is easier.
    Roger
      Here's some basics on motors: http://www.metalwebnews.com/howto/el.../elec-mtr.html
        Roger
        Thanks Roger.
        The starter winding is hard-wired to the switch and capacitor, but reversing the poles of the run winding is a simple matter. I'll try that and report back.
        Pete.
        Monarch 10EE 1942
          Worked like a charm, of course.
          Thanks Roger, and dp.
          Monarch 10EE 1942
            I've modified my 3-phase 415V contactors to work on 240V in order to switch this single-phase motor. I think this circuit will do it - can anyone see a problem with it?
            Monarch 10EE 1942
              It's not safe to have the start winding and start capacitor connected to the line while the switches are in the off position.
              Roger
                I can't see another way of reversing the motor with the hardware available. I do have spare new 240V contactors but there's no room in the box for them. If I must, I will use a third contactor but I'd rather not have to.
                Is there another way of wiring this? I thought my RCD would take care of any potential earth faults on the cap & winding being left hooked to the neutral line.
                Monarch 10EE 1942
                  Roger
                  probably ok here in the uk ......we got one live and one neutral remember
                  all the best.markj
                    Do you have room for a normally open relay? Put the coil across the run winding so that when it pulls closed it connects the starter winding to the line.
                    Edit: Excellent point, a-e.
                      Roger
                      Don't sweat it.... About half the equipment in the world has only ONE switch element in its power switching...... Thus only switching one line.
                      Sure that one probably SHOULD be connected to neutral, but you can't count on that in Germany, for instance, the Schuko plug has no polarity......
                      I would, for choice, be sure that the unswitched line went to neutral. That's better.
                      But, the mains switch is NOT a "disconnect". In CE countries, you cannot have BOTH the "I" and the "0" marked on the switch actuator UNLESS it breaks both mains lines. That distinction obviously shows that not all do.
                      All equipment passing CE or UL or CSA has to pass all insulation tests in such a way that it does not matter whether what you THINK is the neutral really is.
                      The only item I can think of in the US that really makes any difference that way is a floor or table lamp. The screw shell is supposed to be to neutral. But the bozo electrician may have had a hangover and wired wrong, even if your lamp has a polarized plug.
                      As for the UK, there may be some issues locally that I am not aware of. But we sold-in equipment that opened BOTH mains leads, AND equipment that opened only one. All got marked CE with the approval of our NRTL.
                        Like J said, there is nothing wrong with that design due to the start circuit. I design and build industrial control panels with UL508 and ETL listings and that design would pass without a problem. The only thing I see that might be a potential safety problem is that there is no lockout on the contactors to prevent BOTH from being activated at the same time. This all depends on how you plan on switching from forward to reverse. If it is with a mechanical switch that won't allow both to be on at the same time then problem solved. If however you plan to use pushbuttons then there is a problem. If both contactors are activated at the same time the mains will be shorted out and Boom Boom Also you should have a disconnect switch for safety, this is a switch that completely disconnects the mains or a plug in would also serve this purpose.
                        Robin
                        Robin
                        Happily working on my second million Gave up on the first
                          Hi.
                          Here in the UK all 240V equipment must be either earthed or double-insulated. Mine will be earthed and protected by the RCD both in the workshop and in the board in the house, so I think I'm good. The two breakers are mounted right alongside each other and each has a mechanical plastic arm that springs out the side and locks the other out.
                          Many thanks to everyone who has replied.
                          Pete.
                          Monarch 10EE 1942
                            What's a RCD?
                            I didn't know the electrical system in Europe had 240AC with one side as a neutral.
                            There's SO much I don't know.
                            Roger
                              Sorry Roger, and RCD is a residual current device. It's purpose is to detect any tiny current going to earth and isolate the supply. They are typically installed in the domestic distribution panel, but we also have standalone RCD's and plug-point ones for using electric mowers etc. They don't provide overload protection though, unless it creates a fault to earth.
                              http://en.wikipedia.org/wiki/Residual-current_device
                              Monarch 10EE 1942
