Who don't make mistakes ?
  • Who don't make mistakes ?
    OK we all make them, anyone who says they don't is only lying to themselves.
    So converting some Rotabs to stepper drive and they need a combined nut, thrust and Oldham coupling to save space, Simple bit really. Milled the Oldham coupling bit on the end and start to centre drill then drill and tap for the nut part.
    Crunch, centre drill pops it's clogs off, take it out the chuck, bang it on the vise, will the damn bit fall out [ no they never do ] so right seeing as it was the damn centre drills fault it can be responsible for getting itself out.
    Stuff it in a temporary holder so as not to burn my tiny, dainty pinkies and grind it up free hand as such.
    Front.
    and
    Underneath.
    Basically it's a trepanning tool of fixed radius when held in the tailstock chuck. The radius has to be larger than the broken bit and seeing as part of it is on the tool that's the bit you have to grind past.
    Back in the 3 jaw chuck with the part, modified centre drill in the tailstock chuck and feed in slow with lube and you will get the broken bit standing up on an island.
    I was going to take a picture of it but as I took it out the chuck the broken bit fell out and disappeared into the black hole, known all over the internet as Johns Floor ™
    Not a new idea, God knows how many decades old ? but still a time saver and I though on topic for a home shop forum.
    Proof that other people do 'asplode drill bits! HA HA! I AM VINDICATED! MAHAHAHAHAHAHA!
    *bookmarks thread*
    Humor aside, nice way to save a busted bit.
    Now my question is what exactly is a "trepanning tool" and why would I need one?
    ...all I come up with is trepanation which is the art of drilling holes in the skull. My lathe at home isn't quite big enough to swing a normal sized adult and I'm not sure how to get around the neck-snapping issue. Mount 'em in the tail-stock? Or is there a fixture I need to make?
    Plastic Operators Dot Com
      new to me
      Hey John, good trick. I know you won't believe this but I never break centerdrills, but if I ever do I will remember this. Yes, I do use them every day but always have enough speed and coolant and make sure tailstock is dead nuts centered and be very gentle. Peter. ( Is Man U going to end up on top? )
        Thanks for an excellent idea and pictures to match.
        Does your QC department allow chatter marks on the bottom of a hole like that? If mine did, I'd get myself a beer and in a little while QC would quit whining.
          Waste not, want not
          Now, that gem is going to save a bit of stock and a few scribers from destruction
          Ken.
            A trepan is a tool for cutting large discs from sheet metal. Very handy tool and surprisingly accurate I've found. Easy to make.
            Here's one: http://www.enuii.org/risley/training...ing_tool_s.jpg
            Monarch 10EE 1942
              John, just noticed that you're out of the virgin business? Were you disqualified when you hit 61?
                No I posted before, it was the lack of them that forced me out of business.
                The last known sighting was in 1924 on the Cadbury's chocolate firms outing going to Blackpool
                Tiffiepedia fails to publish the results of the return trip.
                  Thats a great idea. But why not use a carbide center drill or some type of carbide cutter to remove it? If a carbide center drill was used then the hole would not be oversized.
                    who DOESN'T make mistakes, or was that they humour bit
                    the mistake isn't busting the centre drill, its using a centre drill when you're not drilling a centre.....I have never busted the pip off a centre drill while using a spot drill
                    using a centre drill to start a hole instead of a spot drill maybe the most common shop error; there are good practical reasons for not doing so.....yet everywhere you turn people start holes that way
                    good creative corrective action though!
                      I don't make mistakse. What's the prbmleo?
                        I don't make mistakes either. I'm perfect.
                        Thanks for sharing John. I hate broken center drills.
                          I thought I made once, but I was mistaken...................
                            Here's some other "ready made" trepanning bits for those of you that have led a sheltered life ;-)
                              I have to agree with Mcgyver, I only use center drills when spotting for a lathe center. I use spot drills for locating holes, center drills are too fragile. And with a 90 degree spot drill I can do a 45 degree chamfer at the at the top of the hole in the same drilling operation.
                              Mark Hockett
