Trepanning Tool.
  • Trepanning Tool.
    Peter wrote in Sir John's thread:
    "A trepan is a tool for cutting large discs from sheet metal. Very handy tool and surprisingly accurate I've found. Easy to make."
    Here's one: http://www.enuii.org/risley/training...ing_tool_s.jpg
    Peter, did you make that tool? If so, what does the "pilot" on the bottom fit into?
    Is the cutting tool a long piece of round toolsteel ground on the cutting end?
    Do you have a picture of the cutting tool shape?
    Is there any problem/trick to getting the top and bottom support arms aligned so that the cutting tool is at 90؛ to the table?
    That looks like a very solid tool!
    I didn't want to hijack John's thread. The beauty of this BB is how one thing leads to another!
    Rgds
    Michael
    Australia
    No I didn't make it (I found that pic with google images), but I did make a quick-and-dirty one to cut a 110mm hole for a filler cap for my bike. It wasn't of the quality of that tool but it did the job. Unfortunately I butchered it for another fitting.
    The basics are simple. The spigot in the bottom of the tool fits into a pre-drilled pilot hole in your workpiece and the top in your chuck or quill. For a cutter I simply ground a short parting tool from 1/4 HSS bar and mounted it vertically, held with a grub-screw. Mine didn't had just the one bar but the one in the picture would be much better.
    Monarch 10EE 1942
      I couldn't get the link posted by the OP to work, but I found it anyway. Here's another attempt to show the tool. You will have to scroll down the page until you see the trepanning tool.
      http://www.enuii.org/risley/training.../tool_time.htm
      Other trepanning tools:
        Thanks Peter, I have one of the cheap "made in India" ones that sounds like the one you made. It has worked on plastic fairly well but I wouldn't like to push it too hard.
        That one in the photo is built like a "Brick Outhouse"
        I wonder if it would be worth trying to balance it, by putting some sort of sliding arm/arms out the opposite
        side? Maybe at slow speeds not necessary?
        Rgds
        Michael
        Australia
          Thanks Jim, that was an interesting site.
          I think that "chain wrench" would be illegal here.
          Rgds
          PS Ok thanks for adding the photo of the other trepanning tools. The one on the Left is exactly a more solid version of my bought one.
          Now, how was the Square hole made??
          Michael
          Australia
            It's almost identical to the one I made. I drilled a round hole and used square stock with a grub-screw. Not too bad if you keep the cutting bit short.
            Monarch 10EE 1942
