It took longer than I expected to get to this stage. In large part that was due to some machining procedures taking longer and also because I was sidetracked last weekend doing auto repairs.
The thick bottom plate is the actual carriage and is mild steel. All of the rest of the components above that are cast iron. Most of the parts were taken from a low cost import X-Y table. The overall quality of the table was dragged down mainly by lack of attention to detail such as proper fitting of the dovetail ways and crummy fit and finish otherwise. The cast iron however is first rate and well cast.
The cross slide has a travel of about 7 inches from the front to centerline but can continue to the back for a total of 10 inches travel. Swing over the cross slide table is a hair under 9 inches. The top slide has a travel of about six inches once I get proper lead screws mounted. Swing over the top slide table is about three inches. Because the tool holder can be set back on the table and because of the type of mounting base I used for the top slide it is basically a built in ball turning attachment that can do up to 3 inch balls.
