puzzle ..what's wrong?
  • puzzle ..what's wrong?
    It's a British two pound coin .......can any of you spot whats wrong
    ALL THE BEST.MARKJ
    It's only worth a pound ?
    [edit]
    Just looked at three, all different dates obviously, but all look the same.
      If you try to drive the geartrain from any one gear the last gear in the train will try to turn the driving gear opposite the way it's driving.
      Monarch 10EE 1942
        Cogs are locked, can't turn.
        Edit, beat me to it!
        I no longer own tools I had.
          I should have said Americans only ..,then thread may have lasted a long time
          yes peter ....odd number of gears ..
          explains ....why GB is going to pot.....when they cant even get things like this right .
          all the best,,.........mark
            Heat it up and then freeze it and see if the centre pops out. Seeing that you stole the idea from Canada's two dollar coin I thought you should know about this. The question is is each part worth half the original?
              No the outside bit is worth more because there is more surface area
              You can't press the new ones out as they have a lip in the inner bit, Early ones you could and some even fell out hence the design change.
                You might be on to something there Evan. Make the center-part removable and you would be easy to give £1 in change for a £1 item.
                Monarch 10EE 1942
                  What's wrong with it is that it's not in MY pocket,please post it to me tomorrow.
                  Allan
                    If those little circles are supposte to be gears, they had better find a
                    different artiste' to do the design. GACK!
                    ...lew...
                      Brilliant,do away with paper money and coins and just use nuts and bolts for currency-I'd be rich
                        Dont be beating on him about that, the Canadians ripped off the idea from the Italiano's...
                          What? The part about it falling apart?
                            Is that coin where they got the idea for crop circles?
                            Len
                              No - I was talking about this comment,,,,,"Seeing that you stole the idea from Canada's two dollar coin I thought you should know about this."
                              I of course wanted to use my own smart ass comment and did, I really dont know where the multi-composite coin was developed but I think there's a good chance it wasnt Canada
