What is this spring clip/clamp called?
  • What is this spring clip/clamp called?
    My pal, Jim, needs some of these things, but doesn't know what they are called to search for them:
    Frank Ford
    HomeShopTech
    Frank,
    Wow, 33 views no replys.
    They are not called "clamps"
    It is a split spring bushing and/or spacer.
    Looking at your photo, tho the intent is applicable, it is open far more than should be provided the correct one of use was installed.
    Following is just one type in the following:
    http://www.connexusa.com/
    This is only one example. Search under the terms I listed and you should find what you are looking for.
    Patch
      i DUNO, 90% of the pics posted here I cannt see. They are just a box with a red x in them. EVANS pics I can see....... I dont know what he is doing that others arent...........
        Frank, it's a "Spring Steel Compression Ring"
        Spotted a tiny picture in one of my old catalogues and looked up the UK website for more info.
        http://www.harrisonsilverdale.com/fa...01/CR/239.html
        Edit: Heres's another (UK) source: http://www.designassemblies.co.uk/pr...gsteel_030.htm
        Peter
          ahidley,
          Until you get your photo X's figured out,
          Click on the links Peter and I provided and it will give you an idea of what the pic is in Frank's post.
          Hope it helps.
          Patch
            Thanks guys - that's just what we needed!
            Frank Ford
            HomeShopTech
              "photobucket.com" and similar hosting websites are bad news for a lot a forums. If you are getting small rectangles with a red X, it means that your corporate network filters out anything graphic that is sourced from a public image storage website like Photobucket.com
              If you hover your cursor over the red X and right click, then select "properties" from the menu, it will tell you the source of the graphic that is not showing up. I have the same problem from where my day job is... I have to wait until I get home to see the photos...
              Most other forums that I frequent host their own photos just so that this is not a problem for their subscribers.
                For what it may be worth, my photo is hosted by me, on my desk at home on my Mac G5. . .
                Frank Ford
                HomeShopTech
                  it is a clamp ring or if made in China is a "cramp ling"
                    Or on a GM its called a hose clamp Seriously though...I do hate the stupid spring type hose clamps.
                    Paul
                    Paul Carpenter
                    Mapleton, IL
