Help with new indexing head
  • Help with new indexing head
    Does anyone own or have a working knowledge of this Semi-Universal Dividing Head? I've purchased a new B-0 model and instruction manual is not written well and I need some help.
    Harold
    For those having fought for it, Freedom has a flavor the protected will never know.
    Freedom is only one generation away from extinction.
    Exactly what do you need help on?
    There is quite a bit in Machinery's Handbook about doing dividing.
      I have a Vertex model which appears Identical, I have used it to generate Square & Hex ends on round components and also for gear cutting, what do you need to know?
      Regards,
      Nick
        Harold, (or others)
        PM me with your email address and I will send a number of files that I have saved and that you will find useful, including instructions.
        I would post the links but all that was saved were the files.
        Ken
          Mine was of very poor quality, paid $300 new for it. What I did to improve it was to mesh the worm tight, then attach a drill motor to the crank shaft and let it spin and spin. Tighten the mesh and spin again. After a few hours most of the backlash was gone.
          The holes in the index plate are another matter - some are .020" off from the others. It will take considerable time to replace these. There is an inherent error correction - it's split 40:1 and doesn't cause problems on small work, so the incentive to fix these is low.
          Using the head is simple fractions. divisions/40 and finding a hole plate that works out to support the remainder. If the remainder is 5/7, that would equal 25/35 or 25 holes on the 35 hole circle.
            What makes it a “Simi-Universal” Dividing Head?
            Doesn’t look like it does any thing different from my plain Ol’ Dividing Head
              Hi Guys!
              First light has yet to come to Alaska and already many have responded to this post. I thank you!!
              Here is my question ....... and problem. Most dividing heads have "neutral gear". When in neutral gear one can freely rotate the work without having to use the hand crank. I cannot seem to find any instruction in the manual regarding "neutral gear". Does this unit have "neutral" and if so, how do I engage neutral?
              Thanks Guys.
              Harold
                Originally posted by hwingo
                Hi Guys!
                Thanks Guys.
                Harold
                It does, it is engaged by not turning the crank
                  Remove the handle & dividing plate & you will see an adjustment for the worm mesh, take the worm out of mesh,
                  Nick
                    Hi Nick,
                    Thank you for providing this information. I will give this a try today. Really appreciate your response.
                    Harold
                      A universal dividing head comes with and uses a stack of gears. Here's an example:
                      http://www.hhip.com/products/catalog...php?CatPage=86
                        I have always been under the impression that a universal dividing head had gears or some other provision for it to be driven off a power table feed enabling it to cut a spiral or helical gear.
                        Mac
                          This too was my impression. Gears are necessary to cut spirals for it to be considered a "Universal Head".
                          Harold
                            Mine has a stack of gears and it is a Dividing Head. It also has a "Through Bore Spindal"
                            I also have an Old Cincinnati "Super Spacer" which has a stack of dividing plates and an adjustment dial.
                            I sold the 1 that had the box of gears ment to run off the X table feed and turn Helical Gears. A Company named "Boston Gear" bought it
                            Dp
                            Now that I scrolled down the page of the link you provided I see what your talking about.
                            So what is the difference between a Dividing Head and a "Super Spacer"
                              Gears on a universal dividing head are also used to make divisions not achievable by just using index plates. Divisions like 51, 53,57,59,51,63 etc, etc..
                              These have to be geared so you gain or lose one tooth by the time you make 40 cuts. You have to remove the index pin holding the index plate steady. It can be pushed in and locked. Now your plate being geared to the main dividing head spindle will advance slightly or retract slightly to compensate for the one tooth.
                              Loved the old No.2 B&S Universal Mill together with the B&S Universal Dividing Head. And yes - with a Universal Dividing Head you should have a Universal Mill. Good way to cut spirals.
