Chuck Mounting Question
  • Chuck Mounting Question
    What is the difference between an A1-5 and an A2-5 mount? I read somewhere there is "no difference". If there is no difference why do they have separate designations?
    P/R
    Never heard of a A2 mount.
    http://shopswarf.orconhosting.net.nz/chuckmt.html
    May be this will help. What is it on? What kind of machine ?
      A1 & A2 American Lathe Spindles
      P/R
      A-1 Has tapped holes on both inner & outer bolt circles.
      A-2 Has tapped holes on oter bolt circle but none on the inner bolt circle.
      Lane for ref!
      Les H.
      The Impossible Takes Just A Little Bit Longer!
        Thanks Les,
        According to the diagram an A-1 will fit an A-2 but not the inverse. That clears it up. The machine is a Haas TL-1.
        P/R
