What is this?
  • What is this?
    Ok, people. Identification required. I truly do not know what this is but have had it in my posession for many years. I don't recall exactly how I came to own it.
    The 6 inch tri-square is for size reference. The item is chrome plated and seems to be very hard material. All machining of this item appears to be by grinding and the finish, while good, is not micro-inch. The marking on the head seems to be "J5C 9" or possibly "J50 9". It has three flutes with teeth, right hand. The head is a bevel gear.
    I have a guess but have not been able to find anything in the category I think it is that even remotely resembles it.
    Don't know the exact name, but it's one of numerous 'finger's in mechanical cotton pickers. Those fingers rotate as the machine straddles the row of cotton, and as they rotate the teeth pull the cotton from the bolls. The bevel gear on the end is, of course, to drive the rotation of the 'finger'.
    (I picked a lot of cotton (manually) as a kid and early teenager, before the mechanical pickers gained widespread useage here in the south.)
    Not sure if the current pickers still use that same technology. There's one just like your's in my dad's garage he acquired somehow, probably 30+ years ago.
    [This message has been edited by lynnl (edited 08-13-2003).]
    Lynn (Huntsville, AL)
      Is it used to remove scales from fish?
      While we're playing what's this, take a look at this:
      http://www.rcuniverse.com/gallery/sh...hp?photo=17356
      Any ideas?
      Roger
        Lynnl,
        How certain are you? The flute teeth are slightly chipped and the point looks somewhat damaged with the chrome gone and the metal somewhat deformed/abraded/battered, just on the point. The shaft shows no wear and neither do the teeth of the bevel gear, only some rust. The bevel gear teeth are somewhat crudely shaped as if it was not expected to be driven for long.
        Winchman,
        That other doo-dad looks like something I would use to help manually pull a well string from a water well. It would explain the wiper in the slot below the pully. That would help clean the rope that is used to pull the pump and string.
          Evan, that wasn't a guess. (tho sometimes I do guess) But I know, for certain, what those are.
          Now having said that, I'll admit that I can NOT say with certainty that the same type finger was NOT used for some other purpose as well. But it looks identical to what I know to be cotton picker 'fingers'.
            Evan, this link shows a picture (drawing actually) of those fingers. It's on about the second page of the text.
            A better view is on page 5.
            http://www.clemson.edu/psapublishing...GENG/EC648.pdf
            I'm not sure, but I think those fingers or spindles are considered consumables and are replaced regularly, due to the abrasive wear. That would explain the crude bevel gear.
              Lynnl,
              It sure does look like a cotton picker spindle to me too. Mystery solved. That has been nagging me every time I saw it for decades. Thanks.
                Evan,
                Some else suggested it was used to lower a coax cable and video camera into a well for inspection purposes. That use seems to make the most sense. The pulley would fit a coax cable nicely, and the wiper would remove excess water from the cable before it went on the reel.
                Roger
                  One thing I've always wanted to see, but never have, is a duck/goose picker. I've often tried to visualize them.
                    lynnl,
                    The duck/goose picker I owned a few years back had four legs and a head and tail, wet nose and answered to the name of Defer ('D' fer Dog!). The duck/goose f**ker was a Browning 12 bore over/under!
                    Sorry for the irreverance! I am always amazed at the quality and quantity of knowledge on this site. If only it could be bottled.....
                    RR
                      RR, I like that name 'Defer'.
                      Had neighbors once whose cat was named 'Sidewalk'. I never learned where that name came from.
                      You're right, it is fascinating, that whatever question or issue (trivial or otherwise) raised here will always produce a good answer or explanation from someone. Usually I can only read the responses in total awe.
                      Lynn
                        This explains the origin of the phrase; "I wonder whatinhell this cotton pickin' thing is."
                        Jim H.
                          Never thought of that, but I'm sure you're right JC.
                          (See there. ...another mystery solved!)
                            BTW,
                            They still use exactly the same parts. You can buy them for $2.39 ea for a John Deere cotton harvester. Looks exactly like mine.
                            My original guess was some sort of rock anchor, possibly for climbing, as permanent aid using a angled rachet drive to set it. It would probably actually work quite well for that if you could figure out how to drive it. That is, until I read about how they are carefully heat treated so hard that they are guaranteed to break before bending so they don't thrash the cotton pickin machine when it eats a rock.
                              $2.39 ea?? Mygosh, at that price I'm tempted to get a half dozen or so myself, ... and I don't even need 'em.
