Tool for flycutter
  • Tool for flycutter
    Want to mill a flat surface using a small mill (600 watt or 3/4 hp DC motor). Mfrs claimed capacity is 2-1/2 in face mill.
    Trying to decide between a single point flycutter http://busybeetools.ca/cgi-bin/picture10?NTITEM=B090 and this 3-insert carbide http://busybeetools.ca/cgi-bin/pictu...TITEM=B2136MT3.
    The carbide includes the insert bits (3) but the single point uses standard (non-supplied) tool bits.
    I'm thinking "standard tool bits" means lathe tool bits. What shape would I have to grind on the bit?
    Can I expect a smoother finish with the multi-bit carbide?
    If the single point fly cutter and 3-point carbide are set to the same diameter of cut (ie., 2 inches) do I need to adjust the speed/feed/depth of cut of the carbide vs the fly cutter (since, I am thinking, the carbide has 3 cutters vs one)?
    Any other pointers appreciated.
    Thanks.
    Here's a thread at CNCZone that includes a nice image. It's the shape I use.
    http://www.cnczone.com/forums/showthread.php?t=28295
      Yup, that's what I like also. I put a bit of a radius on the 'bottom' corner to improve the finish. Works a treat.
      Pete
      1973 SB 10K .
      BenchMaster mill.
