Boring head project advice
  • Boring head project advice
    Got a few hours to go play in the garage again, started on the boring head I've been wanting to make. I have quit a bit done but have some questions before I finish up.
    1. If I have a 40 tpi screw should the dial be 25 or 50 graduations? I was going to go 25 but this would be .002 per graduation, the norm is .001 correct?
    2. I used a piece of aluminium for the for a temp gibb, can this be brass or does it need to be steel? Or maybe copper? I have copper that's why I ask.
    3. The third boring bar hole on the side or end, is this useful or should I leave it out?
    Here's a few pictures of the progress, it's approx 2 1/4". Thanks for any help.
    Clinton
    Nice work there. Some of those questions could just be a matter of personal choice.
    When I made a boring head somewhat like that I did put 50 graduations on the dial. There's room for them on your circumference, and if there's ever any confusion about whether it's that much on the radius or the diameter you'll err on the safe side (more to take off).
    Brass or steel would be better choices for gib material than copper. One might argue steel for strength or brass for non-galling but you're not likely to have problems with either in that situation.
    I put a square hole straight through in mine but have to say I've never used it. OTOH, I've read comments from people who have used that feature so if you're giving yourself all the options you may as well go for it.
      Beautiful work!
      40 tpi is 0.025"/turn so 20 minor divisions and 5 major divisions would indicate 0.001"/div. If the dial does not become cluttered then 50 divisions would present 0.0005"/div which is a darn fine line on a boring head. You can probably estimate that at just 25 divisions.
        I have used all the holes say like a really large bearing bore you might use the side hole and i have used one of the end ones for turning a boss on the side of a hit and miss model so more holes more options
          Very nice work. Brass, steel and cast iron are the usual choices for gibs and I have seen some from acetal or other rigid plastics although I would not recommend them for this application. I think copper or aluminum might not have the smooth movement you will get from harder materials.
          Most boring heads graduate the dial in actual material removed, so the actual movement of the slide is doubled. Jan's suggestion of 50 grads equates to 0.001" on the bore.
          The cross hole will be appreciated if you have it when you need it to do a large bore, and it is easier to put it in now than in the middle of a job if the need should arise.
          Jim H.
            Dang Clint, you shore do purdy work!
            This is strictly 'for what its worth' - absolutely no scientific backing (Destroy this tape when finished, etc, etc)
            During my recent rebuild on the Katrina South Bend lathe the shop gremlins stole the gibs for the saddle (never has shown up either!) I went to the scrap box and got a piece of ?? iron/steel and trimmed to fit, then put it on the surface grinder and made sure it was flat. Installed it and despite adjustments/oiling it just wasnt smooth.
            So I've got this big cast iron base off a junked chinese planer and I band sawed a piece of cast off and repeated the grinding etc and changed the gib out --- whoa!, what a difference...smoooooth.
            YMMV
              Thanks for the suggestions guys, I guess I'll either make the gibb out of cast or brass which ever I find first. The aluminum was just to lock it together so I could machine the rounded sections on the body. This and my other 2 projects started life as part of this had 2 given to me, they were 5"X 5" X 4". I should really stop being so cheap and buy proper sized stock.
              I think I will also add the third hole, mine as well if I have in the vise.
              And 50 graduations it is If I can get them all to fit, the dial face it only 5/8" diameter.
              I'll post up some more as I get time to work on it, and thanks again.
              Clinton
                If you say youve been slicing those blocks up with a hand-held hack saw ...........
                Do you know what the blocks are? Sure looks like it machines up nicely.
                  No no hand hacksaw not that cheap. I bought a 4X6 bandsaw off kijiji after buying the lathe. I believe the guy I got them off said they were 1018 but I can't be too sure. They came from Bucyrus they build mining equipment so It could be something else. It does seem to machine pretty nice though.
                  Clinton
                    Looks great Clinton -- I gather you're following Ishimura's plans?
                    http://homepage3.nifty.com/amigos/bo...ing_head-e.htm
                      Bloody nice work Clinton. Looks like you've been working through the page of projects on the mini lathe workshop page. I just saw that yesterday and that and your work so inspired me that I've decided to build some of them myself. I like that the drawings are available for free and easily read too. Keep up the great work buddy, and remember - we all love pictures - the more the better
                      Monarch 10EE 1942
                        Beat me to it Lazlo
                        I really fancy that keyway-cutter, and I have a job for one too.
                        Monarch 10EE 1942
                          Yep I contacted him a while back to express my gratitude on his webpage and all his great info and to make sure he did not mind me building some of his great tools. I changed some of the dimensions on all the projects so far but they are close for being imperial instead of metric. I should have bought some round stock for this like he started with, would have made the project easier. But having a guide like this makes getting into the metalworking hobby way easier.
                          Clinton
                            Another very nice project. Looks like you copied a Maxwell boring head . I have one just like it . Factory uses steel gib , but cast iron are brass is fine. keep up the first class work.
                              Boring head
                              Damn nice work. For sure put the cross hole in, great for large bores also you can put your boring bar in and use it as a flycutter. Peter
