You all have seen Steve's (S_J_H) neat little CNC lathe build take place on this forum. Well, due to the terrible missfortune of loosing my father, I was able to trade a neat little drill press he had to Steve for the little lathe. Well, most of it anyway. Steve removed the CNC parts for his HBM build, so I need to recreate those parts. And he also kept the VFD and drive motor. I don't think I will be able to improve much on this thing, but my first order of business was to CAD it all up and start messin' around with ideas. I'm much better with CAD than machining, so I'll do all my tests on the screen before cutting metal. I'm going to try and get the cross feed screw under the cross slide. The 5/8 screw I'm using makes it a pretty tight fit, but I think I can make it work. The only "problem" is that with the double nut, the screw will have to extend out the back pretty far. I may try a smaller screw, but it looks like its only marginaly better, with 2 or 3 times the cost.
Anyway, here is some renders I've done so far.
