treadmill motor controller delay
  • treadmill motor controller delay
    I have just adapted, a treadmill motor to drill press, and have a problem with about a 4 second delay, from the time i turn it on , till it starts.. It is a old mc-30 controller.. Does anyone know how to correct this??
    Patience
    <Sound of knee slapping laughter>
      The variable speed drill press at the school also has a delay when the speed is set very low, but it's only a little over a second. It's not as bad when the speed is set higher.
      Roger
        If that is a treadmill controller, it sounds like the soft start they build into the controller. It is a safety feature to keep the motor from starting instantly while you are standing on the treadmill. There may be a way to override it but I have never heard of anyone doing it.
        Gene
          There is probably a surface mount pot on the board used to set the accel limit.Find it and you could probably tune it to your liking.
            Lets view this as a carefully thought out addition you added to the circuit that allows you to turn on the machine and get your hand back to holding the piece to be drilled . . . at least that is what you say to friends when you show them your masterpiece.
            Planeman
              Have a schematic?
              Try looking on GE's site - They built the thing
                That's a really old model. Can you take a closeup of the board from directly overhead and post it?
                  I'm sure you're not holding the workpiece by hand as may have been suggested above...... on accounta it's a good way to get hurt...
                  A suggestion re: 4sec delay.... push the start button 4 seconds before you want to drill the hole. Just my attempt at humour!
                  But seriously I have a friend that lost a finger and effective use of 2 others from holding a workpiece in a drillpress! Tore the finger off tendons and all, pretty grim event and I am almost phobic watching people on a drillpress now.
                  Be safe guys.
                  al
                  I spent most of my money on women and booze, the rest I just wasted.
                    Safety
                    Thanks for your concern, I have been a toolmaker for 35 years building progressive stamping dies. I just started a home shop to build minature engines.
                      I'm sure if you posted a picture of the board someone here could may be able to help you fix that. I have a small bandsaw that I put a dc motor on and the potentiometer that controls motor rpm has to be turned down to 0 before it will start. Like was said this is a safety for the treadmill but maybe not needed for a machine tool. I never bothered to see if I could improve it, I just got used to it. Good luck.
                      Jonathan P.
                        You can defeat it,
                        There is info somewhere, maybe the rec crafts metalworking site, on how to do it.
                          mc-30 controller
                          I found out that the delay is in the design of the mc-30 controller, so I decided to upgrade to a mc-60, which is a much better design and does not have the soft start, and will work fine with the exisiting dc choke.. Thanks to all for there comments !!
                            Cure for treadmill motor turn-on delay
                            I bought a bunch of treadmill motors from Surplus Center that came with controllers that had to be turned down to zero before the motor could be re-started. I hacked the board to eliminate this feature. It has been running fine for many years. The hack involved severing some lands and bridging others. I have the photos of the board and the hacks somewhere. But it will only work if it's the same board. Can you post photos?
                              I happen to like the soft start feature and have found a way to make it more user friendly.
                              With the controller I have that came with the motor, if I break the connection on the center lug (wiper connection) of the control pot the motor will come to a stop. Making the connection again will soft start the motor and it will come up to whatever speed the pot was set at.
                              Gene
