I recently got sick of the compressor on my prehistoric Cat 922B loader putting copious amounts of engine oil into the air tank, so I decided to do something about it.. I pulled the compressor off and as expected the bores were heavily scored and the pistons were also scored..One a lot worse then the other... I initially thought oversize pistons would be the go, but while the service manual mentions them the parts manual makes no mention of them..
A phone call to the aftermarket/wreckers parts supplier and yes they had a "good" compressor in stock and for only $850..OK, maybe not...
So why not bore it out and make up two new pistons and rings to suit, after all I am a master machinist in my own mind....
I have done a fair bit of machining but usually that is usually non accurate work or plain but accurate simple work..A shaft here and there, a stub axle or four, keyways, threads, just basic stuff..
I bored and honed the bores first..A simple job and quite easy to do...Next was the pistons..First up was measure the old piston and get some drawings..I use the free solidedge 2D program for my drawings..I find it quick and easy to use and quite powerful...
I already had the CI rod in stock so chucked it up in the four jaw (because my 3 jaw does not have a 50mm bore), turned it to near size then sneaked down to the required size, the first one I got spot on....Next was the grooves for the rings..A shaped HSS tool did the trick but since I have no DRO on the lathe I relied on the top slide to get the grooves in the correct spot, tricky to keep remembering how many turns you have done to get it to the correct position... The oil ring groove has a taper below it and as I have no way of measuring the taper I guessed it and it seemed OK...
I parted it off and started the next....It went pretty much the same but I made it a tad smaller then I would have liked...Still within the tolerance the service manual gives but only just..
Next was boring out the inside of the pistons..Disaster struck me there, upon reading the diagram I drew I went about boring it out to what I thought was the correct diameter, only to realise I had read the wrong figure on the drawing...The old saying..."I drilled it twice and it is still too big" came to mind..
A few choice words later and a cup of coffee and a check of the emails and the HSM site I was cooled down and went back and made a new piston.. It went straight forward but again I went took too much off the OD then I had liked...In fact I made it the same OD as the one I stuffed up....This working to fine tolerances is hard when you are relying on just the dials of the lathe..
Next was milling out the bit for the con rod... Something I believe I only wasily accomplished because of my new DRO on the mill....It made it super easy to find where I wanted to cut..I am still very much an amateur on a mill, a lot more knowledge is needed for one of them then with a lathe..
Next was boring the holes for the gudgeon pin (wrist pin for the US) Here I struck the trouble of lack of tooling..I had the required adjustable reamer 7/16 was the size of the needed hole..But I had no collet to fit the initial drill and had to go with a ISO30-->MT3 adapter and then a MT3 shank drill chuck..So it ended up about 6 inches long without a drill, which did nothing positive for the runout...
Anyway I stuck the piston in the vice, got it lined up with the help of the DRO and drilled the first hole....I then chucked a small boring bar to enlarge the hole the tiniest amount so the reamer would enter and do it's stuff ( I really have to invest in a proper drill set) I had done several test holes previously to this and it had all worked out well but murphy intervened and for some reason my "drill" took out more then expected and when I used the reamer it took out bugger all metal..Upon testing fit with the gudgeon pin it was snugish but there is a tiny bit of movement..it will be loctite to the rescue when it comes to fitting. The second one went much better and turned out as expected..
The little 1/16th holes was the next challenge..There is six drilled in below the bottom ring for what I presume is oil holes...They are on an angle...measuring this angle to what I thought was 33 degrees I tilted the mill head over..Mounted the rotary table on the table and chucked up the piston... When I got them all drilled I realised the angle was far too shallow and that it looks to be closer to 45 degrees..oh well, it should still work...
Anyway I only have the rings to do now and I will do them later this week or on the weekend..What this has taught me is the skill needed to make accurate items is not something easily attained..I thought I was fairly good with a lathe but working to thousands and sub thousands does take a lot more skill then you think..These pistons are a bit rougher then I hoped and it is yet to be seen if they will last 1minute, 1 day or 10 years..
I am sure you can work out which one is the home made one..
