I just recently acquired the above saw. I have several questions for guys that have used this saw. This is regarding the operation. Speed and rate of feed.
I am now running it on the slowest. What should I set the speed at?. Feed (weight of saw) should be set at what?.
How do I tell if there is not enough or too much?.
I will be cutting mostly steel rounds ranging in diam. from 1/2 up to 3 inches.
Thanks,
Jack
Thanks,
Jack
