When doing machinery repair (in particular, automotive ), do you use any lubricant on the threads of fasteners during reassembly?
I've heard a LOT of different information on this. Notably:
"You should always use grease or motor oil on bolts, so they will come out without trouble next time."
"Anything other then dry threads will affect the clamping force at a given torque, and lead to over tightening."
"Only lubricate fasteners on the suspension/undercarriage, where fasteners experience dynamic loads and attack from the elements."
"Clean bolts with wire wheel, the use axle grease before reinstalling."
"Clean bolts with wire wheel, then install dry."
Personally, I clean them up with a wire wheel if corrosion is present, and almost always install dry to the spec'd torque. I was just wondering if there is an official stance on this. It does seem that lubricant on the threads will lead to over tightening due to lowering the coefficient of friction between the mating threads.
Thoughts?
Thoughts?
