I have two shafts from a 1950’s Brown and Sharpe surface grinder that are bent… These are about 15 inches long and about ½ to 7/8 diameter inch where bent. I haven't had a chance to put these in V blocks etc, but they appear to be a "simple" bend in one location. In the pics below, the threaded shaft is bent just before the junction of the narrower section - the threaded portion appears straight. The splined shaft seems bent closer to the middle.
I have a couple of choices… try to straighten them myself, or send them out to someone who might know what they are doing… These are not available., and would cost a bunch to get remade. They don’t appear to be hardened, but it’s unclear what steel they are made from. It has fine surface finish even where turned and could even be leaded steel.
I imagine a lot of electric motor and other shafts get bent… and fixed… Anyone know companies that do this work? I might get enough courage to try this myself, but I’m not really sure where to start… any hints? I have a surface plate, v blocks, lathe for center, arbor press, and shop press. Would this be done cold or with some heat?
