I needed to remove a rear hub from my '53 Hudson. The rear hub on these is a keyed taper, and if they've not been off for a while they can be fairly tight.
First I tried the modern sophisticated approach and set a 10 ton hydraulic puller on the end of the hub. I checked progress once a day and after a week figured maybe it wasn't going to work.
Today I tried the more traditional approach, ie a piece of 1" plate across the end of the axle with 3 x 1/2" UNF grade 8 bolts into the wheel bolt holes. I tightened the bolts progressively with a 1/2" rattle gun on 120psi air and the hub loosened at the point where the rattle gun was just about at maximum torque.
Clearly the 3 bolts were more effective than the puller, possibly the shock from the rattle gun may have helped.
My question to those who understand these things is thus. Do 3 x 1/2" UNF bolts used as described really deliver way more than 10 tons of pull, or is it more likely that my 10 ton puller doesn't really pull 10 tons?
