I've been steadily working on this #12 for a little bit now...minor probs here and there,mostly leaks (if theres a seam there it'll leak shortly
). Heres the question for everybody.....the power feed gear box seeps around the change lever shafts,quite heavily in some cases...after taking apart I found there is no seal to speak of there.After thinking about this,and being that the shafts are a pretty tight fit in the bore,it almost seems as if the oil is getting warm under use and "pushing" out...does this gearbox not have a vent of any sort?..(theres none that I've found)...after machine sits overnight and then gets put into use,can the temp difference cause this? I did take the time to convert the drive to a belt to get rid of the worn out howling chain,but that didnt seem to make a difference one way or other....
