Gents--I would like to construct a tubing notcher and would value recommendations on the appropriate bearing to use for the spindle. This would be similar to the ones you have all seen on various sites for tubing notchers and powered with a hand drill of less than 500 RPM. Here is one of the best I have seen so far:
I picked up several Thompson Linear Bearings on eBay a few years back but wasn't sure they would be capable of both the axial and radial load. These fit a 1.000 shaft.
Yes, I know a bushing would be the easiest way, but this is project is more "art" and the tool itself than the easy of construction and function, in other words yes, I want to over engineer the heck out of it.
Any suggestions on the appropriate bearing? And in advance, thanks!
