Ned help in finding a tabbed washer...
  • Ned help in finding a tabbed washer...
    Pretty much says it all.
    These are the washers that you bend up a tab into a slot in the nut. As best I can tell, Mcmaster does not have them... they have tabbed lock washers but those are different. I need to replace some on a old machines so OEM isn't an option.
    I was looking for some a while back, and found them in the auto parts store. I can't remember the name of the company that sells small packages of miscellaneous parts on carousels in the parts stores, but that's where I found them.
    I think they have a website, too.
    Roger
      The company is Dorman/Motormite. And they do have a web-site.
      If they don't have it, you'll probably have to make one.
      No good deed goes unpunished.
        Check out:
        http://www.seastrom-mfg.com/
          We purchase the nuts/washers you're talking about (or similar) from Whittet-Higgins...
          http://www.whittet-higgins.com/
            Perfect. They have exactly what I'm looking for.. their PW or PWT series.
            many thanks.
              Any good bearing supply house will have them. They are called N washers and are used with wo nuts.
