Bought an electric motor for my son's bike. It fits on the front wheel where the hub would normally go. The unit came attached to a rim but someone from a country not known for it's quality control must have slammed it down on a workbench when he was finished with it. It has a 10" flat spot on the face of the rim and yet the cardboard box nor the styrofoam it was packed in showed no sign of damage. It has an anoying whop, whop, whop when you ride it
The rim that was on his bike to begin with is exactly the same except they screwed up and it's round! Will it be a nightmare to swap out the rims? I have studied it and can't figure out the logic of how it's done. Is there something I'm overlooking? Keep in mind, I have to remove all the spokes first before I can start to install them on the good rim because I have to remove the hub-motor. In other words, taking them off one and a time and installing on the other rim is not possible.
I've come to the Chapel of Tech Savvy twice today and won't bother you with a third trip!
This is the motor I"m talking about.
