aloris qctool post
  • aloris qctool post
    Hey,
    A friend gave me an Aloris toolpost holder. It is a bit banged up. the name plate says Aloris tool Post model looks like SX or 5X, under the mane plate in the body is 221. The holder has AXA2. I have only the one holder. It could take two. My question is: I assume this is a 2 series???? CDCO toolholders should fit? Buy depending on size of toolbit?? Thanks for any help in advance. Best to all Fred
    If the AXA holder fits properly I suspect you have an AX toolpost, AX is piston, AXA is wedge for the holding mechanism, what is the swing of your lathe?
    AXA2 should be a straight or V facing and turning holder IIRC
    Many knockoff brands go 100 series AXA, 200 series BXA.........
    Opportunity knocks once, temptation leans on the doorbell.....
      Hey thanks for the help. My lathe is a 9" swing the tool holder is indeed a piston.
