OT / Glass glue?
  • OT / Glass glue?
    Hi all,
    My wife broke one of her favorite glass jar lids, which is also glass. So now I am looking for the best way to repair it. Is there a glue for glass that actually works that you know of?
    Thanks, Jay
    "Just build it and be done"
    Wouldn't super glue work?
    Make it fit.
      loctite do one that sets on exposure to sunlight ( will not set behind glass window ) so you can set the parts up , say with your door shut then open the door , glue set ) BTW the glue is clear
      Its Called Glass Bond
        Clear nail polish! It works fantastic. I have glued cracked aquariums, porcelain, china, glass. It always works as long as you can line the pieces up. A real life saver, readilly accessible and cheap. Fred
          Glass Glue
          The professionals use a special made epoxy glue. You can find it at Talas Co.
          http://apps.webcreate.com/ecom/catal...roductID=18872
          It's rather expensive but anything to keep the wife happy.
            Rear view mirror adhesive. It requires ultra violet light to set up so do it on a sunny day and leave the part in direct sunlight for a couple of hours.
              check out : thistothat.com
                I'd look at what Loctite has to offer.
                  Jay take a look at this web site, it has a glue for all things. It has a calculator thingy that allows you to enter what your gluing to what?
                  http://www.thistothat.com/
                  looks like the Locktite is the answer
                  Mel
                    Mel
                    Wow, neat site!
                    Thanks for finding it.
                    Pete
                    1973 SB 10K .
                    BenchMaster mill.
