tapered pin
  • tapered pin
    Had a pin dropped off to the shop this afternoon
    The small diameter is 0.708, the large diameter is 0.760 and the o.a.l. is
    2.5". The numbers work out to be a 1/4" per foot but I could not find
    what number taper pin reamer this is.
    The pin came out of a water generator made in the UK in approx the early 60's.
    I may not need the reamer, but would be nice to know if needed in the future.
    eddie
    please visit my webpage:
    http://motorworks88.webs.com/
    A No.11 taper pin reamer is 0.700" on the small end and 0.875" on the large end.
    Jim H.
      My Machinist Handbook shows the largest tapered pin listed as a #10 with a large end Diameter of 0.706 inches and a length 3.3 to 6 inches. A number 10 Reamer has a large end of 0.7216. Is it possible someone reamed this thing over sized?
        MH only lists up to #10, they are available up to #14, which is just over 1-1/2" on the large end.
        I measured a #11 I have, it looks like the actual sizes are 0.7060" & 0.878".
        Jim H.
          Found it in the Travers book # 11
          0.706 on the small end 0.878" large end, and 8.250" long
          eddie
