oiler for oil/grease nipples?
  • oiler for oil/grease nipples?
    I just received a manual for my Beaver VBRP. It of course has a oil/grease schedule within. Most of the oil points are serviced by a zerk fitting, but the schedule calls for oil not grease in nearly all points.
    Where do I find an oiler for these fittings?
    Thanks.
    Brett Jones...
    This is what I use on my Bridgeport. Made it from one of those mini grease guns, leaks a bit but works well.
    http://www.metalwebnews.com/howto/oi...unconvert.html
    Russ
    Master Floor Sweeper
      I've known several guys that have tried to make the Metalweb oiler, and they all leak
      I bought the German pressurized oil gun from McMaster: 1879K48
      It's $70
        To prevent leaks between the oil gun and the nipple, just put a piece of cloth between the two, this will allow the oil to pass through and form a seal to prevent leakage.
        Malc.
          I modified a grease gun, by simply welding the end of the tube shut. It was a mini-grease gun, about half the size of a normal one.
          I use this on my Myford lathe, and have now also converted to real Zerk-nipples with 2BA threads (bought from Myford), instead of the original and special Tecalemit ones.
          Oiling is very easy now .
          Thomas
          Problems worthy of attack prove their worth by hitting back
          - Piet Hein
            I just use a regular grease gun and hold it with the back end up. Put
            the Zerks on aimed up, had to use a few 45 deg. ones on the
            Bridgeport. Store the gun in a gallon can with the top cut out. Doesn't
            even leak much when using it.
            ...lew...
              Myford oil zerks
              Hello, Also have a Myford & converted a mini grease gun. Made the ba threaded zerks by using drive-in zerks. They are soft enough to thread - single pointed in lathe with a holder that holds the nipple end with set screws. Regards, Earl
                I found a neat little grease gun that uses plastic tubes for the grease. I emptied the tube and put in Way Oil, it works great. Had oil in it for over a month and no leaks yet. Look for a Lubrimatic Jiffy Luber.
                http://www.outdoorsuperstore.com/pro...sp?prod=499115
                A local hardware store was going out of business so I bought several. If you cant find one locally let me know, I have extras.
