A Greasy Spot To Be In... Or A Little Oil Goes A Long Way
  • A Greasy Spot To Be In... Or A Little Oil Goes A Long Way
    Ok I think I may have created to mess for myself. The Sheldon has a few zerk fittings that take oil. Well I grabbed the wrong gun today and squirted a shot of light grease into the spindle pulley back gear drive sprocket. Now this only moves when running the back gear. Now can I just flood it with oil or do I have to tear the spindle down and clean it out.
    Memo change the color of the oil and grease guns.
    So what say you?
    Run it,the backshaft prolly doesn't turn up enough revs to worry about.
      Oil should flush it out over time. I wouldnt be too worried about it. South Bend uses a grease in their back gear.
        That's kinda what I thought but then again I've been know to be wrong on occasion. And the fact I've read countless times here about the grease and spindles = bad. So I'll continue to flush with oil and use caution in the future. Thanks
          My lathe spindle uses grease.The only place I've been told to absolutely not put grease is on the ways.
          Monarch 10EE 1942
