Today I just returned my first indexable tooling I bought for the Bridgeport: a 2" Tri-Dex endmill, 3 insert TPG style endmill. I don't have R8 so this is the only straight shank model that I see on Enco (my eyes tend to miss expensive.)
I used it for few seconds but it sounded more like a fly cutter. One of the inserts was much lower than the other ones, and was the only insert cutting.
Removed and checked inserts - all within less than a thou or so, so it's gotta be the pockets on the endmill. Pockets checked, cleaned up, checked for rough edges, and inserts are indeed seated perfectly.
I chucked up the endmill in the lathe, and dialed it in the 4 jaw to within a few tenths. Using the test dial indicator, I carefully measured the endmill length/depth on each insert tip. Total difference was 0.010". That is to say that relative to the middle insert, one was higher by 0.005" and the other was lower by 0.005" when endmilling.
Is this something that just slipped by quality checks or am I expecting too much from economy tooling? I don't know if I should try the same model again and see if it cuts OK, or just get something different altogether.
What do you think?
-Matt
What do you think?
-Matt
