Takasawa lathe tail stock
  • Takasawa lathe tail stock
    I am trying to locate a used tail stock for a Takisawa TSL-800 Lathe. (MAX 800 DELUXE) SER BSE80480H. Date of man 1978. Any help would be greatly appreciated.
    BOB
    Enter the brand name in a search engine, you might find a distributor on the net for this brand, or replacement parts. Then make the calls. I might even take this challenge.
    CCBW, MAH
      Bob
      go to www.thomasregister.com and then go to thomas register gloabal search. If you cannot find it this way I think you may have some trouble (like you don't already know that ;-) ) getting one.
      Thomas Register lists around 85,000 manufacturers & distributors and the global is even bigger.
      Good luck
