So I need 20 small beryllium copper roll pins, .125" diameter, 1.25" long, .028 thick wall. No luck finding a source, apparently beryllium copper is out of favor but it is spec'd and no substitutions are allowed. It seems that it would be too small to make with a roller so I'm thinking of milling a groove and pressing the material into the groove, flipping it over and hopefully being able to press it around a pin into the groove and finish the diameter. Will it work? Any thoughts on a better solution?
Ward
Ward
