flywheel difference
Corliss
I am guessing that he is saying to look at the different flywheel he used (on the engine) versus the one supplied with the kit, which is unpainted on the far right. I think either looks great. Especially on a beautifully done model of a Corliss. My kit is patiently waiting for its turn.
Jim
If you want to move them into one, all you need to do is to choose one thread to put them in. Go edit one of the OTHER thread's picture post, copy its "image" line, and then edit the 'chosen thread", pasting in the image line you copied.
Go to next "other" thread, copy its image line, etc.
When done, you can just delete all teh ext in the un-needed postings.
I think this site allows 4 in a post, after which you have to start a new post in same thread.
To do it all at once in a new post, do what you did to post the one picture, but do it several times before you "submit" the post.
The image line should look something like this:
IMG]http://img.photobucket.com/albums/0803/jstanley/handvise3.jpg[/IMG]
except that it will have a "[" on the front. I had to take that off to make it stay as text. Otherwise you would have just seen a picture.
I think there are full instructions posted in a "sticky" postCNC machines only go through the motions.
Originally posted by topgunEvening,
I'm sorry, but I don't know how to post pictures all in one post. So give me heck and tell me how.
Don
Leave spaces between the lines. Now hit the 'preview post' button. You'll see that all your links have [URL] tags around them. Change those to [IMG] and you're done. Hit preview again to check it's worked. You can put lines of text between the picture links to make a 'storyline' or add descriptions. You can only add 4 pics per post on HSM, any more have to go in a reply.Peter - novice home machinist, modern motorcycle enthusiast.
Monarch 10EE 1942
