checking my work
  • checking my work
    The old motor in my Sheldon died (bearings) so I picked up a Dayton 3/4hp 230v to replace it. The motor is model 5K460C and the drum switch I'm using is a GE model CR102B. Both components have their respective schematics but I want to run this past people who are in the know and make sure they're compatible. The drum switch is powered by a magnetic switch.
    Here are some photos of the docs (sorry, they are big).
    http://www.5foot2.com/forum_pics/img_0439.jpg
    http://www.5foot2.com/forum_pics/img_0441.jpg
    Thanks.
    Brett Jones...
    yes the "t" leads are all labeled the same and have the same function from the limited view i can see of the print. t1 and 4 are one winding and don't change and T3 and 5 are switched to reverse. if the motor goes in the wrong direction swap 1 and 4 or 3 and 5. to make it right.
      The switch schematic shows T2 splicing into T3.
      I'm assuming I can just run a jumper from the T2 lug to the T3 lug on the switch?
      Brett Jones...
        I wired this motor and switch up this evening. It works on one direction, but when I try to reverse the rotation it trips the breaker at the panel.
        I'll be double checking my wiring tomorrow when I can look at it fresh, but until then does anyone have any ideas?
        The switch says "instantly reversible 5 lead motor" on the schematic. And the motor that came out did have 5 leads. Is it that I have the wrong switch for the motor I'm running?
        Brett Jones...
