boring problems...
  • Your Old Dog
    That's pretty slick JC.
  • JCHannum
    When building a model John Deere engine, I was faced with the same problem. I made a sub table to replace the compound. I used a piece of 1" thick aluminum.
    I cribbed the casting in place and used hold downs to hold it in place. The rear of the engine would not premit line boring, so I made a very stout boring bar to hold the cutter.
    I had acquired this gage in my roamings, and it works very well for setting the cutter protrusion. For one time use, a similar gage could be made by clamping a depth mic to a V-block.
  • .RC.
    Mybe it is just me but I can never bore holes sucessfully with a boring head on a milling machine...All I get is constant chatter..
    I would be setting it up on the lathe or getting it honed..
  • Oldbrock
    Piston valve bore
    Too bad you live so far South, I could hone it for you on my Sunnen hone. Find someone close to you who has one, should clean up in an hour or so. Peter
  • barts
    started a topic boring problems...
    boring problems...
    I need to clean up the 1.25" diameter, 5" deep bore for the piston valve on the 2.5" x 2.5" steam engine I'm rebuilding... and my 2" boring head doesn't look like it will be happy w/ a 1/2" diameter boring bar that long.
    I thought about line boring it on the lathe, but can't figure out how to mount the cylinder on the cross slide w/ a lot of complications, and setting the protrusion of the toolbit seems awkward as well. I guess I could bolt the cylinder on the lathe faceplate, but that's a lot of cast iron winging around. ...
    The simplest idea seems to be to get a bigger boring head so I could mount 3/4" boring bars.
    Has anyone got a better idea? What do people thing of the cdco tools 3" boring head?
    - Bart
