new power supply
  • new power supply
    Thinking about uprating the transformer on my sieg X3 conversion, it's running out of steam at high revs.
    Will this one do ?
    Should just be able to squeeze it in.
    Looks good, you'll be done in a flash!!
      and possibly a bang....
      handily theres an emergency number easily to hand
      Did you get any floor with that?
        Hmm. I'd be lookin for something with more amps.
          Going for 1500ipm rapids?
            Out of interest what is the output of one of these in amps ?
            That copper block on the top is the actual winding.
            Its 1" x 1-1/2" solid copper and it has two 'turns' inside the box around a laminated core with the primary windings filing the bottom.
            Two people can 'just' lift one between them, so say around 300 - 350 #
            Knowing to company it's come from I'd say it's off something to do with welding pipe seams
              5700 Amps it says on the name plate looks like 50% duty cycle with 5 liters per minute water cooling.
              Its a spot welding transformer.
                Not obvious from pic one but one of the terminals is snapped off on this transformer that's why it's in.
                The break isn't clean and it then requires a new terminal.
                Again from pic 1 this brute is nearly 24" high and won't go on any of the mills and get a tool onto the top face,
                so think outside the box and rotate everything thru 90 degrees.
                So layed on the bed, horizontal attachment fitted with extended 1/2" cutter to clean the broken face up and then tap for two M12 brass studs to hold a new terminal block down.
                It was a panic job as the plant had come to a stop and in the rush forgot to take a pic of the finished job, this must be about #5 or#6 that has been done this way.
                Apparently they are supported from a travelling crane and they keep bumping them into things at the local pipe works.
                  John
                  Those 90' attachments come in very handy...
                  I use it alot with shoe mould work.
                  I will take some pics next time...I am getting better with the cam??
                  great job
                  eddie
                  please visit my webpage:
                  http://motorworks88.webs.com/
                    Yes pictures are nice but I keep forgetting even though I take the camera into the shop every day because of the development work for the Chinese if I get an hour to do some.
                    This job was typical, I'd actually unbolted it and put the cutter away before realising it would make a good subject, hence no clamps and no retaining bolt for the collet.
                      "camera into the shop every day because of the development work for the Chinese if I get an hour to do some."
                      Hope you are not part of that internet spy ring
                        Clumsy bastards.
                        I never have liked European wiring practices.
                          Safety
                          Its nice to see the use of flotation device to prevent Death
                            Looks OK to me the slippers should have the CE mark so that passes all tests
                              5700 Amps at 14V-19V at 50% duty cycle is what it says on the plate. Which fits in with the 100KVA rating.
                              It also needs 5 Litres per minute cooling water.
                              It would make a wonderful car battery charger
