Benchtop Gear Head Punch Press info needed
  • Benchtop Gear Head Punch Press info needed
    I've got a small back-geared head mechanical clutch punch press similar to a Benchmaster, but even heavier built, of recent but unknown origin and manufacture. There is no name plate or numbers to be found. I'd like to know its approx capacity and if there is more tooling available for it. I've done a fairly thorough Google search using all variations of "small benchtop gearhead punch press" and no hits. Any suggestions?
    thnx, jack vines
    Pictures might help identify it.
      You might also try Googling Arbor Press.
      But if You are as lucky as I am on Google that wont help either .
        Benchmaster is one of the more common manufacturers of small presses. You might find some help on their site.
        http://www.benchmaster.com/
        Jim H.
