Idea machine work light?? off the shelf at HF
  • Idea machine work light?? off the shelf at HF
    http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=66308
    Like $25 currently, 120vac input.. one on each side my mill head would probably be just fine with me. NO building, no work.. is 120 vac on a machine thou, use a GFCI..
    Excuse me, I farted.
    270 Lumens? Thats a little more light output than HALF a 40 watt light bulb. In other words, not much. Can't beat the price however.
    James Kilroy
      What I like most about these new LED Bulbs is very very little Heat.
      Especially with work lights where I can be directly under them.
      My old Halogen Lamp on the Lathe, can be a real cooker.
      A lot of earlier Bulbs had a Blue Cast that I did not like, however, recently I replaced my chandelier bulbs with "Warm White" LED's. Looks great with only a slightly lower overall brightness, but, with a greater than 90% power savings!
      As a bonus, I'm thinking that some of these can be repaired should a LED go out. Typically though, I think LED's tend to just get dimmer and dimmer over time.
      I do notice that the Blue Cast Bulbs make my complexion look younger, so I need to use a whole butt load of them.
      Tom M.
