OT: RC Sidewinder Missile
  • OT: RC Sidewinder Missile
    This is too cool. Can anybody see for sure how it is propelled? I suspect a small prop in the slots of the forward fins. It sure does fly well.
    http://www.metacafe.com/watch/941727...inder_missile/
    Found a copy - there are indeed counter-rotating props (!) in the slotted fins which helps to explain the good control when hovering...
    http://www.rcgroups.com/forums/showthread.php?t=501856
    RC gear is a lot smaller than when I were a lad...
      Here's another vid from the same guy:
      http://www.metacafe.com/watch/223712...new_freestyle/
      Amazing.
        I can't tell you how many hours of stick time it takes to have the type of control that gentleman has of his models.
        The massive strides in electric motor/battery efficiency and the reduction in size & weight of the r/c gear is fantastic stuff but the skills and hand-eye coordination required to perform that little video is indeed awesome.
          But if you look at some of the displays using "Conventially Shaped" airframes on the same site ???????????????
          Regards Ian.
          You might not like what I say,but that doesn't mean I'm wrong.
            SO, how many of you flew a model using a rubber band powered escapement?
            How many of you still have the escapement and receiver?
              A good pilot, and "Gyros".
              Gene
                Evan, Mom threw out my Babcock escapement and Aerotrol rcvr about 40 yrs ago.
                Circlip, I was referring to the 2nd video dp linked to. That's some awesome flying.
                  Neither, I did build a receiver with an ?? XFG1 gas-filled triode ??, for a boat not a plane. Never completely finished the model, though
                  Tim
                    Still got the rubber band
                    Some years ago I was sorting some boxes out and found my old single channel R/C control, probably one of the early transistor models all it could do was switch a relay.
                    Switch a relay ??? the light went on.
                    So while Gert was out I put this across the back of the doorbell went across to my mates garage opposite and waited.
                    Gert came back, put the shopping away and settled down.
                    Ding Dong.
                    She comes to the door and no one there, settles back down.
                    Ding Dong.
                    Rushes to the door, thows it open, no one there.
                    This went on for a few minutes and in the end she was hiding behind the curtains waiting to pounce.
                    Ding Dong, rips the door open, no one there , just going to close the door and it went Ding Dong follows by peals of maniacal laughter from across the street.
                    In true Queen Victoria style "She was not amused "
                    I was though
                      Practicing for a career as a monk, eh?
                        I looked at the pictures on the RCGroups site and I only see one prop on that model. Where is the second one?
                        Ryan
                          I highly doubt the gyro's. It's all about the CG being correct in 3 planes, not just one or two like most airplanes.
                            Unless someone can document proof that he is not using gyros in the missile I have to believe that he is. It would be a perfect application of what is available.
                            It's those tiny wings and how finite he must control them. An assist would be really cool. And make it flyable.
                            Gene
                              I wager there are no gyros used. Look again at the pics on the RCGroups site.
                              Ryan
