Micrometer "feel"
  • Micrometer "feel"
    Starrett tells me that after their micrometers are thread ground they are lapped.
    I have some micrometers that are very smooth and have a great "feel" to them. I have others that aren't very smooth and that don't have the "feel / smoothness" that I prefer.
    I wondered if anyone has every lapped a micrometer to make it smoother and how it worked out? If you did what kind of lapping compound did you use and what grit(s) did you use?
    I lapped one that had some rust damage to the threads.I used plain,white,cheap toothpaste.It has a mild abrasive in it and does a good fine lap with a little patience.
      I can't speak to exactly how starrett laps the threads, but when stuff is lapped, its lapped against a lap - not its mating parts. doing that would just increase clearance making it a sloppy fit. lapping can put exceptional finishes on, but I can't see it being a trivial task making the thread laps especially when you can by a Starrett mic new for a hundred and something or on ebay for 20 - 30 bucks
        I'm told by Starrett tech support that they lap the mating parts of a micrometer together. Still trying to find out what they use for a lapping compound.
          then i stand corrected. for lapping in general that's not the way to do it as you cant control how/where material is removed, although i guess if the compound was so fine it barely removed anything....maybe it is toothpaste they're using .
            Must be...my micrometers have never had any cavities!
            David
            Montezuma, IA
            David Kaiser
            ― Robert A. Heinlein
              Since the mics have a take-up for thread wear, lapping could be done with anything which won't "charge" into the parts...... It won't make the parts sloppy, since you can adjust them back into any desired state.
                When I was young and dumb, i lapped a Craftsman mic with valve grinding compound.
                Needless to say, valve grinding compound is waaaaay too coarse for lapping a mic.
                Nonetheless, the mic worked much better after lapping.
                Haven't tried lapping mics since then, but I've been tempted, because I have a set of import mics that are next to useless because the "feel" is so rotten. You can't get consistent readings because the "feel" is too rough.
                First thing to try is merely drenching the threads with oil. That fixes a lot of them.
                My knock-around shop mic (the one that sometimes gets dropped on the floor and otherwise abused) is a Horror Fright that was worthless when new due to the crummy "feel." I drenched it with Kroil and that, combined with several years daily use, resulted in a mic that works just as well as any name brand.
                  I would be cautious about lapping a mike. The fit of the threads is very important to the accuracy and repetability of the readings. In fact, I would not do so at all unless the nut was adjustable to take up any slack you may create.
                  On fine threads I have made, I find that a good quality grease (or oil) will improve the feel a lot and is removable if you don't get the results you want. Try that first.
                  Make it fit.
                    When I took a tour of the Starrett plant in Athol a few years ago, I actually saw them doing this.....
                    A row of guys sitting at benches, with a geared "speeder" setup they can clamp a micrometer in and turn the spindle quickly. They apply some very watery (though I assume it's really thin oil, not water) lapping compound, spin the spindle, test the "feel," take out the spindle and bang it on a lead block if it feels slightly mis-aligned...repeat until they're satisfied. They are FAST -- no more than a couple minutes a micrometer, as I recall. But they are truly hand-fitted. I would hesitate to do it myself. Those guys have had a lot of practice.
                      Paul, I've soaked a micrometer with a lousy "feel" with Starrett Tool And Instrument Oil that was recommended to me in another thread for something else and the "feel" is still horrible. Do you think changing to grease would help? If so what kind of grease... lithium based, synthetic, or?
                        I also would be hesitant but you could try diamond polish:
                        MCMASTER
                        MSC has a better selection but only in oil soluble.
                        I used to do a lot of mold polishing with them and occasionally some lapping. A piece of brass and some brown or purple diamond will put a nice edge on a knife.
                        I would start with yellow.
                        Jon Bohlander
                        My PM Blog
                          I would add here that the abrasive in toothpaste breaks down and becomes inert during use.It won't embed and forever be lapping away.
                            How would I go about lapping the anvil with diamond paste? Maybe make a lap out of of wood or brass and slide it back and forth over the anvil? I'd like a looser fit between the anvil and frame.
                              BRASS LAPS at the bottom of the page. They are expandable to compensate for wear. Or you make something similiar. We used copious amounts of steel ink remover to clean up diamond paste. Other strong solvents would probably work. Steel ink remover is the WD-40 of the tool room. It's always around and gets used for all sorts of things.
                              I personally would start with maroon Scotch-Brite, WD-40, and elbow grease. Great combo for cleaning rust from precision parts. Twist the Scotch-Brite into a cone and insert into the hole of the frame and twist away. I've had good success freeing up the auction special mics I tend to drag home with that method.
                              Edit: I just noticed you said anvil. Drill and ream a hole in a piece of brass. Drill & tap a hole off to the side and saw through into in the hole. Use a bolt to tighten it up as it wears. (Like a shaft collar)
                              Jon Bohlander
                              My PM Blog
