Cross Slide Lock for Grizzly G4003G
  • Cross Slide Lock for Grizzly G4003G
    I have had my Grizzly G4003G for almost a year and like it very much. One of the problems I have had along with a few other members is the lack of a cross slide lock. Because the DRO is mounted on the tail stock side there is no way to get to the gibs to lock the slide. After a number of attempts I came up with this solution. I uses the 2 shcs that hold the upper portion of the saddle to the lower section. It is a simple block of 6061 drilled & counter bored for longer shcs and 2 threaded holes with brass heads to hold the slide in place. I used 3/8 16 threaded rod and put felt on the end of the brass. I used 2 but 1 would probably work. I often wear a belt & suspenders (braces for those of you across the pond). On the first job I had to cut some 1.625 crs down to .25 leaving a small shaft sticking out of the large dia. The cut was .015 deep and the lock held the DRO to .00000 to .00002
    Hope this helps someone here as I have gotten so much help from others.
    thanks
    ed
    That looks like an easy solution. If I'm not mistaken it covers the oilers for that side of the carriage, though, no? I have the little brother of that lathe and at least on mine it would be a small effort to relocate the oiler and drill through. I'll have to take a look tomorrow when it's warmer in the shop
      Does not cover the oilers, they are on the tail stock side.
        Excellent - mine has two there but it looks like they can be worked into the design. Thanks for the nice idea!
          How timely, I was wondering how to do this on mine because I have the DRO on the tailstock side, thanks for the great idea, I'm building one this weekend.
