Hi there
I have come across a Beaver Antares cnc lathe here in Ireland for sale but I cannot find anything out about it from all the usual web sources. Does anyone know anything about these machines?
It has Antares stamped on teh enclosure and a nametag from Beaver UK.
There is an Olivetti control system.
It's an unusual layout - when you open the machine the chuck faces directly out towards you. The toolpost and turret are between you and the chuck.
It has a 6 post rotating tool turret as well as a few toolposts.
There is a hydraulic system and it looks like this drives the chuck closing and also the 6 post tool turret.
The chuck is some kind of collet chuck but there is also a three jaw chuck included.
I can see a resolver motor driving one of the axes.
My original plan was to buy an old cnc lathe and replace the control system with a PC based Mach 3 system. I'm not sure if this is going to be a suitable lathe so would appreciate any info if people know anything about it.
The use of hydraulics is throwing me a bit - is this a good or a bad thing?
