OK I give up... What are these things?
  • OK I give up... What are these things?
    http://s624.photobucket.com/albums/t...ssidedr/Rests/
    They have to be some sort of rest for a turning part as the fingers have wear resistant tips but for what machine? I can't see them being used on a lathe as I don't think they could adjust to changing radius. I got them with a large lot of other fixtures and stuff at auction. This shop did a lot of grinding so I wonder if they might have service on some grinding machine that I'm not familiar with.
    Thanks,
    Doug
    Steady Rest for a OD Grinder.
      Doug,
      What is the height of the green one from table surface to center of horizontal finger?
      I may be interrested if it is for sale.
      Or, I can sell you the grinder for it
      Thanks,
      Glenn
        Originally posted by Glenn Wegman
        Doug,
        Thanks,
        Glenn
        Thanks for the replies, mystery solved!
        Glenn,
        Distance is 7.25" near as I can tell. PM me if you are interested.
        Thanks,
        Doug
          Doug,
          I'll check tomorrow to see if it is the one I need.
          Thanks,
          Glenn
