Todays project, a wrench
  • Todays project, a wrench
    So, i was in need of a spindle nose protector for my SB13, 2-1/4x8. I was in a bolt specialty store in Little Rock and they had this large nut on the counter, measures 3.109" side to side. I ask how much for the nut, he says go ahead and take it, so i did. Here is the nut re-threaded to 2-1/4
    But now i need a wrench to remove nut and Collete closer. Ah, i have some 1/2" aluminum plate i got from the scrap yard. So with drill press to drill through at each corner of the hex, a copping saw and a file, then the table saw to cut the wrench out of the plate i have this
    Good idea nice work.
