Tee Shirt Launcher
  • Tee Shirt Launcher
    Here some pics of that remote control t-shirt launcher that was in the pic with the injection molding machine at TechShop.
    It was built with the kids at Tigard High School Robotics. 9 barrels, can fire 3 shirts in each barrel. The elevation is with an old seat adjuster from a chrysler town and country that was a warranty reject.
    More Pics at: http://www.flickr.com/photos/techshoppdx/
    Here's a soundtrack for viewing those photos, salute to the t-shirt launcher inventor: http://www.youtube.com/watch?v=1b3pJYfv5eg
    -Matt
    P.S. How many feet per second do the shirts go?
      That audio is great!
      Not sure what the muzzle velocity is. Thought about rigging up some sort of chronograph.
      It will launch a standard shirt about 150 feet. Pepsi cans much further!
        How about a wet t shirt? Tomato perhaps?
        You don't need a chronograph. Set the launcher to fire parallel to the ground at a height of one meter and fire something that has negligible retarding effect by the air such as the Pepsi can. Measure the distance until it hits the ground in meters. Multiply by 2.214 and you have the muzzle velocity in meters per second.
        You can then extrapolate by the ratio of masses from the tee shirt and the pepsi can the approximate muzzle velocity of the tee shirt.
          Or find any decent paintball field. They'll typically have either some radar-based chronies or at least a breakbeam light-sensing type.
          We chronied a potato cannon many years ago- the typical PVC and hairspray style. It'd lob a potato about 200 yards, but at "only" around 150fps muzzle velocity. (That was using a high-end radar chronograph.)
          I'd wager this shirt cannon is in that same ballpark.
          ... Are those socket-wrench U-joints on the driveshafts...?
          Doc.
            yep, they are.
            If they break home depot will replace them!
              lIt shoots at 180 fps. (according to the bud audio)
                It doesn't matter what device you use to throw something, the velocity will be the same for the same angle and range if air resistance is neglected. At these low velocities something dense like a soda can or a tomato will have the same trajectory if you throw it, kick it, bat it or shoot it. Since the attraction of gravity is the same in all cases basic grade 9 calculus applies. That's why it can be boiled down to such a simple term if you fix the other variables as I offered above.
                BTW, if you don't want to use metric then place the device 39 inches above the ground and measure the distance in feet. Then multiply by 7.26 for feet per second.
                  That is Ballistics 101, and while interesting, it is of only passing value. To be meaningful, the range must be dead level and the starting trajectory ie. the bore of the barrel, must be parallel to the ground of the range. Any elevation or depression will skew the results. If these requirements are satisfied, it still only yields an average velocity, not muzzle velocity.
                  Jim H.
                    you guys should debate it for the next thirty pages
                      I learned ballistics in grade 9 as one application of calculus. Calculus is the mathematics of motion over time.
                      Physics of trajectories
                      A familiar example of a trajectory is the path of a projectile such as a thrown ball or rock. In a greatly simplified model the object moves only under the influence of a uniform homogenous gravitational force fieldForce field (physics)
                      Originally a term coined by Michael Faraday to provide an intuitive paradigm, but theoretical construct , for the behavior of electromagnetic fields, the term force field refers to the Line of force one object exerts on another object or a collection of other objects....
                      This is the focus of the discipline of ballistics
                      Ballistics is the science of mechanics that deals with the flight, behavior, and effects of projectiles, especially bullets, gravity bombs, rockets, or the like; the science or art of designing and accelerating projectiles so as to achieve a desired performance....
                      Newton's theory later developed into the branch of theoretical physics.
                      Theoretical physics employs mathematical models and abstractions of physics in an attempt to explain experimental data taken of the natural world....
                      known as classical mechanics.
                      Classical mechanics is used for describing the motion of macroscopic objects, from projectiles to parts of machinery, as well as astronomical objects, such as spacecraft, planets, stars, and galaxies....
                      . It employs the mathematics of differential calculus.
                      Differential calculus, a field in mathematics, is the study of how functions change when their inputs change. The primary object of study in differential calculus is the derivative....
                      (which was, in fact, also initiated by Newton, in his youth).
                      http://www.absoluteastronomy.com/topics/Trajectory
                      I believe I mentioned that. I used fewer words though.
                      This is a Tee Shirt launcher, not a precision target rifle. The results obtained will be accurate to within ten percent or so without taking any special measures. That is good enough. Repeatability will be considerably better as long as the same setup is maintained.
                      As I said, the effects of air resistance at these low velocities are negligible on an object that is reasonably massive compared to it's volume. The terminal velocity of a full Pepsi can will be somewhere over 100 miles per hour which is approximately 146 fps.
                        Based on what information?
                        Jim H.
                          Wait, are we done panicking about Swine Flu yet?
                          Jerry: Great Job! That looks like a blast to build and operate!
                            *passes over popcorn*
                            Beer is the cooler under the mill.
                            Plastic Operators Dot Com
                              Ah, so that's what the door in a turret mill's base is for!
